How to top up your fan clutch
  • How to top up your fan clutch
    As I am going to do mine this W/E, thought this might be worth a sticky
    http://www.offroad80s.com/how-to-top...mod-t1160.html
    Just did mine today.
    1. Be careful with the seal I was careful with mine but it still became magically longer and impossible to put back in.
    2. I threw 30ml of 7000 in the middle figuring that centrifugal force will send it out to where it'll pass through the holes.
    3. I washed in one of those pro fountain things and rinsed with petrol, but beware of petrol touching the seal I guess that's what expanded mine.
    more info:
    http://www.nichols.nu/tip482.htm
    more:
    http://neuralfibre.com/paul/4wd/tuni...ous-fan-clutch
      The 'O'-Ring will generally have 'expanded' and be too long to get back in. Just cut it to length and rejoin it with a drop of 'Super Glue' and reinstall it. It'll be fine.
        Yes I did, plus a drop of sealant on the 'repair'.
        Did I screw up by just putting the thirty mm in the middle, as I said after seeing how it worked I thought centrifugal will send it to the valves that control it. Plus it was all over the place when I opened it.
        I will be keeping an eye on it once hot to check it's locking.
          It will never 'lock' it will always lag a bit, it should lag less as the engine warms up.
