I've had lots of passive help from the wealth of info in the archives here so thanks! but struggling to diagnose this based on my symptoms, I'm not mechanical as you'll realise...
Had trouble starting my imported '92 2.4, initially tried charging batteries and that seemed to help temporarily. However battery level actually seems OK (about 80% on the dash) and, after getting a tip, was managing to get it started with a bit of manual pumping on the fuel filter.
I also had a leaking injector pump to get fixed which I thought might be contributing and this all made sense. However, I've had the leak sorted and still had the same morning routine: try turning over a few times, no joy, manual pump, starts OK with a big puff of white smoke.
If I drive even a couple of minutes in the morning and stop it'll then start fine first time, if I leave it all day at work it'll still start fine in the evening.
This morning couldn't get it started at all and think have run the battery down now so back to square one
Would this be consistent with glow plugs needing replaced? I've acquired it only recently and they were allegedly replaced recently but can't be sure...
any ideas most welcome...
