Ive had a good search and found the problem with a 2" lift on a 3rd gen is the vertical steering shaft then rubs on the exhaust manifold if using a spacer. I understand other people have done a 2" lift but not how they over came the problem.
Other than cutting the shaft and welding a 2" peace in. If doing the weld option whats involved in removing the vertical shaft other than unbolting the bottom end?
How have others overcome this problem?
All input appreciated.
