Long story but ill try to keep this short.
I currently have a 2nd and 3rd gen surfs. On the 2nd gen a similar to the pictured multi plug connects straight into the alarm system.
The 3rd gen obviously once had an alarm and immobiliser however, some wiring seems to be in place but working parts appear to have been removed.
The picture shows the multi plug on the 3rd gen located on the drivers side coming through the fire wall just above the wheel arch.
Multi plugs although in same location and similar in appearance are different on the 2 surfs.
It apears to have been used in the past and the are holes in the wheel arch suggesting something, Probably alarm was once mounted there.
What is the purpose of the multi plug? Whats its Function?
Can i plug an alarm system into it or is it more involved than that?
