Hi Guys,
I have a KZN185 and the electric boot release has been a little fickle for quite some time, often takes a few hits to release it. The door light on the dash dims when the switch is pressed, to the switch must be passing power. However I will by pass the switch and test.
The boot isn't even clicking when I used the switch, it used to even if it didn't open. Is there a way of getting to the mechanism or a manual release from inside so I can check it out?
I assume there is a small motor or something similar that activates the boot mechanism. Any advice would be greatly appreciated as not being able to get into my boot makes having a truck much less fun.
Cheers,
Rob
Cheers,
Rob
