brake judder - BUT with new discs and pads
  • brake judder - BUT with new discs and pads
    as title
    replaced front pads and discs on 4runner recently,
    wheel bearings not loose
    but still getting wheel judder when braking hard
    any ideas?
    I'm going to bleed the system too, as brakes don't feel as strong as i reckon they should be
    andy
    Landcruiser Colorado
    Sub. Forester
    Could be steering idler arms I had judder on mine took it back to the dealer who adjusted the arms now runs perfect.
      yes - to eliminate that
      I replace the idler arm bushes (worn) a couple of weeks ago. The idler arm is firm now, as is the balljoint.
      I have also relplace all the track rod ends - not a job I want to do in a hurry again - on a 9yr old truck
      a
      Sub. Forester
        Possible that one of the discs is not sitting flat on the hub, bit of dirt behind it, spin each wheel to see if disc runs free of pads all the way round or touches at one point.
        My 4x4
        My choice
        Back off
          Originally posted by andycook
          as title
          any ideas?
          andy
          you may have used the brakes to hard as they should be worn in before any heavy breaking, done that my self with the same symptoms as you have........
          CHEERS JOHN................
            thanks guys
            raised the truck, spun the front wheels and RH side wheel and disc touching pad at a point when spinning - like a buckled bicycle wheel. LH side fine.
            So looks like hub has to come apart again, when I have a few hours to spare... so i can get the disc flat on hub..
            andy
            Sub. Forester
