Strange noise on steering.
  • Strange noise on steering.
    Hi guys,
    I've just changed the passanger outer track-rod end and steering idler bushes on my '91 2.4, they were absolutley shot. Also had the tracking done at a local garage while i was at it.
    I now have a quite loud knocking noise when on right hand full lock and i move forwards, it doesn't sound like it's coming from the cv joints but as though something is maybe rubbing or grating on the chassis.
    Due to the weather i haven't had chance to have a look underneath today, but i was wondering if there is anything in particular that i should check? Wondering if after the tracking that the steering mechanisms may be travelling too far in one direction?
    Dazza
    Non consternationes.
    have a search for steering stops and a blob of grease will cure it
      Thanks for quick reply.
      I have just checked throught he steering stop threads,which seem to make sense. The only thing is that none of the links to pics seem to work. Just had a quick look underneath and i assume it's the four bolt type things(two per wheel)that need greasing on the ends.
      Would be doing it tonight if the vodka hadn't come out 1/2 hour ago
      cheers
        that's the ones
          Picture for you
          My 4x4
          My choice
          Back off
            cheers koi,
            off out to get dirty, cold and grease it up!
            Ta
