Its been tipping it down here for last couple of days and Ive started to get water coming into the truck
Got a drip from the rear window I think it is where the CB radio aerial lead used to go through and has damaged the seal I think the water is running down the roof and coming back under the seal and dripping onto the load cover. Any ideas where I can get this seal from?
Secondly - advice needed on this.... Ive got water coming in at the passenger side A pillar I beleive from the windscreen seals as there is water in the footwell (ive checked the heater matrix and thats ok the water is coming from a different place) Some of the chrome windscreen trim is missing and some silicone has been used - would this cause this? I noticed in the cold weather that I was getting some droplets of water running down the passenger side of the windscreen inside but initially put it down to condensation.
I also have a wet patch in the drivers side roof lining in the corner near the top of the A pillar under the right side of the sun visor. it doesnt appear to leak when stationary but after being on the move in heavy rain for a few miles I get a drip that lands on my right arm and the wet patch appears. is this again a windscreen issue? The sunroof appears ok and has a deflector.
Any advice or experience of problems like this would be much appreciated before I drown on the way to work!!
