Well i decided to do them today seeing as im bored stiff at home & don't go back to work until wednesday
Shocks were a bit of a pain but not too bad, hardest part was the top nut but with a large pair of grips on the sleeve to stop it from spinning i eventually got them out.
Springs were easy with the compressors & although the new springs are shorter they are thicker & once fitted the truck sits half an inch higher.
All in all a job well done, next thing is the belts & an oil change.
