David romazewswki
    IT WILL JUMP OUT AT 50 65 70 XX
      mine drops out of overdrive at 50, goes in again at 55 and stays there unless you floor the accelerator pedal or manually turn it off, cruising along over 55 it should stay locked in OD. H
        Maybe a weird question, but is it temperature related? I.e. does it stay in o/d when the engine is quite warm and drop out as it cools down?
          NOT A WEIRD QUESTION AT ALL. I PONDERED OVER THIS MYSELF .AND TESTED THIS OUT AND FOUND THAT TEMP DOES MACK A DIFFRENCE TO THE TIME AND THE RPM OF THE GEAR CHANGING BUT THE OD DOES HAVE A PROBLEM
            Originally posted by lord lucan View Post
            sounds like an ecu promlem, hows hackney these days?
            hackney has bad aterchud stil the same
              ELLO EVERY ONE IM ON THE HUNT FOR A WORK SHOP MANULE FOR MY SSRX LIMITED 3.O LITTLER TDI
                Roughtrax have them.
                  THANKS MATE WITCH ONE WOULD HAVE 1994 AUTOGEAR BOX SSRX LIMITED 3.0
                  • #24
                    There is only one.
                    • #25
                      and, STOP SHOUTING, please
                      私のホバークラフト は鰻が一杯です。
                      • #26
                        There is only one.
                        HIGHLANDER!!!!
                        • #27
                          listen mate if you don't like it #### off ok and shhhhhhhhhh u mouth
                          • #28
                            Who are you referring to?
                            • #29
                              You need a new thermostat.
                              • #30
                                See, its people like you that give us immigrants a bad name.
                                You're on the forum for 5 minutes, 12 posts and you're telling people to #### off.
                                wrócić do domu, kurwa.
                                私のホバークラフト は鰻が一杯です。
