If I engage / disengage 4wd while in neutral it clicks in and out no problem. However if I engage it on the move it takes a short while to 'lock in'. If I disengage 4wd on the move it can take up to 4 miles for the icon to stop flashing on the dash.
My questions are:
1. Is this normal?
2. Is 4wd still engaged while the icon is flashing?
3. Could it be a sticky solenoid and how would I check?
4.This didn't happen when I tested it before buying so could it be due to the freezing weather? (I'm clutching at straws here folks!)
Thanks in advance for any advice given.
My questions are:
1. Is this normal?
