Hello
Attempting to find the cause of the long problem of my 3rd gen surf not engaging 4wd I though I'd see if the the selector actuator was sticking. The actuator came away from it's housing a bit easier than I was expecting and the contacts have rotated from their original postion. I guess that now the thing is really bollxd as even if I find what the fault was ( it's not the actuator selector as all the contacts lok ok and nothing was broken) the motor will power up and as actuator is likely to be out of postion I could have made the problem a whole lot worse. Does anyone how these can be reset their correct position.
Below is a photo of the removed bit.
Any thoughts gratefully received.
