Hi everyone
I have a 92 LN130 2.4. The body work and interior are in excellent condition but the engine has now done 240,000km and is in need of some work.
What I need is some advice from you more experienced Surf owners.
Current state of engine:
The top end is quite tappety
Small oil leak from rear/top of engine (possibly head gasket)
It uses a small amount of coolant and oil (due to leak)
Very difficult to start in current cold weather (new glow plugs last winter)
When cold it pulls away like a slug and it seems generally lacking any power
Smokes an embarrassing amount when I put my foot down
About 6 months ago I had the injector pump reconditioned due to a bad fuel leak and I also had the injectors overhauled hoping it would stop the smoking, it didn't.
Options:
1) Install a used low mileage engine
2) get my current engine recoditioned
3) Get the head rebuilt, replace head gasket (no blue smoke so bottom OK)
4) Buy and install a reconditioned 2nd gen engine
Will a 2nd gen engine fit into my surf with all my existing ancilliaries?
I have seen engineering oufits advertising (on ebay) recon 2nd gen 2.4s fitted for around £1200.
Any recommendations/advice would be greatly appreciated
Options:
