im in fourwheel drive and cannot get it out.this is a 3.0 ssrg 1998.when in fourwheeel drive dash flashes,you know the four wheel display.this is normaly difficult to get out of but today just can,t get it out .any advice anybody before i pull the gear lever out!
stuck in fourwheel drive
Originally posted by toadsting View Postit does go solid as in all 4 wheels green,so what does it mean when it,s flashing?
When it's flashing, the actuator on the transfercase is about to engage/disengage 4WD.
It won't engage/disengage if your foot is on the gas, you need to lift off and then re-apply.
