my surf is still overheating. Have fitted a new head, old one was pressure tested and found to be cracked. Have also fitted new radiator, removed guts of thermostat and bolted the viscous coupling solid. I'm losing about a litre of coolant every 25 miles and appears to be pumped out of expansion pipe. Running the vehicle, there are a lot of air bubbles appearing in top of rad. Am I missing something? Has anyone else had this problem? PLease help!
KZN130 still overheating
 Ya may wanna start with this if ya haven't alreadyOriginally posted by smiffy boy View Postmy surf is still overheating. Have fitted a new head, old one was pressure tested and found to be cracked. Have also fitted new radiator, removed guts of thermostat and bolted the viscous coupling solid. I'm losing about a litre of coolant every 25 miles and appears to be pumped out of expansion pipe. Running the vehicle, there are a lot of air bubbles appearing in top of rad. Am I missing something? Has anyone else had this problem? PLease help!
 http://www.hiluxsurf.co.uk/showthrea...hlight=Burping
 Good Luck
 Jess
 "Cos short cuts can cost more in the long run"Buncefield Burner
