seen some mention of a manifold heater using a ch3/167 champion plug.
plan on taking the egr pipe off and making a blank off plate threaded to suite the plug, any body done this? would like some input,
the plug is a 12 volt 385 watt, going to use a 12 volt 40 amp soleniod and wire a switch into the dash.
