thats the speedo face done and dusted in next to no time thanx to andy`s advice now the bigger job , whats the easiest way to replace rear shocks . got the gas type from milners
how to fit rear shocks
Its no biggy, big bolt at the bottem, for the top, remove the top half of the adjuster unit (2 bolts) then down inside the bottem half is the nut for the top of the shocks. You may need to hold the shock rod with a pair of mole grips if its tight. Most times only need to grip the dust cover by hand.
Anti-sieze on all the new nuts and bolts on case you need to take them off again later.
