Hi folks, I'm in need of some help after having glow plugs break in the head and having to remove head and remove glow plugs I now have hopefuly air lock problems how do I het the air out of the system please
How to burp the cooling system
why only coolant and do you mean anti freeze
we have filled with water and anti freeze i have been driving with heaters on but there is air in the system heaters i think, is it just a case of drive it till it works its way out [ i,m worries about it killing the head gasget ]
the temp gauge went the three quaters yesterday i stopped topped rad up but then its over flows the header tank , i can hear it running & trickling into and around the heater at the front but they blow cold air still so i presume its air in the systemLifes a Surf
Set both heaters to hot, top up with coolant (de-mineralised water+anti-freeze) half fill the expansion tank and leave the radiator cap off overnight.Originally posted by sioux1ok View Postwhy only coolant and do you mean anti freeze
Most if not all of the air will have escaped by morning.
p.s. leave the rad cap on the driver's seat so you don't forget to re-fit it!
take the rad cap off and set front and rear heaters to hot and put on full blast.Make sure the truck is either on level ground or facing uphill.Switch engine and keep topping up via the rad cap and not expansion bottle.it may take a while or it may be quick but once your sure there's no more air in the system fit the rad cap and go for a drive.Allow to cool down and then check the levels again and repeat if needed.There should be in the expansion bottle about 1/3 to 1/2 full max
Make sure you use the same colour coolant that was in the system to start with as you can't mix them.If you change the coolant colour you need to flush the cooling system firsthttps://www.facebook.com/groups/henpals/
Sioux1ok, I'm not having a go at you but you should have done a bit of homework before tackling the cooling system.
All you need to know about these trucks are found in the "search" facility at the top of the page.If its not broke don't fix it.
The problem is the rad filler hole is lower than the front heater matrix, you can fit a bleed valve from a plumbing supplies shop into one of these hoses and use that, burp the system the way its done with a bottle or try my method: both heaters on full and blowing as you top up the system as much as possible, go for a little drive to a place with a real heavy incline, point your truck at it and drive forward till the front end is up in the air, brake on, out of drive and shut it down, open the bonnet and if the engine is cool enough take off the rad cap, if not you'll have to wait, once you get it off, start the truck back up, heaters full blast and top up as it runs, it'll blow bubbles out for a bit then once you think its done replace the cap, drive it home then let it sit overnight with the cap off before topping up again if needed in the morning, works perfect for me. H
Its really not that hard, I put this in the sticky at the top of this forum awhile back if anyone would bother reading it....
Don't worry about the turning the fans on, the coolant isn't bothered how hard the fans are blowingFilling cooling system........
With all the heaters on hot, fill it via the hose that does a 180 deg bend into the heater control valve with a watering can, fill till coolant comes out rad, put cap on, keep filling till coolant comes out of heater control valve and pop pipe back on.
Take it for a run and check it at the rad cap when cold or next morning and it shouldn't need much more water.
as long the valves are on to hot, coolant will flow through the matrix's just fine.
Flush the whole system with a hose through the pipe, till clean water runs out of valve and rad cap, let rad drain, with will give you a block and matrix full of clean water, pour 4-5lts of neat coolant in, then finish with fresh water as above and you'll have right mix and no air locks.
'Done'
