My garage tells me i need to replace my front diff. Where the front half axle goes into the diff you can move it up and down. Is it a bearing that's knacker-ed or something worse, they reckon on 4 hours/ £200 plus to replace the front axle and diff provided everything comes off ok which i doubt it would. Plus of course i've got to find a replacement first. What are my options please or which would be my best plan of attack.
Front diff/ axle.
I'll crawl under tomorrow and take a pic or two. The garage i use is ok, i've known the owner for a good twenty years but i don't think they do a lot of 4x4's. Their view was that it would probably be easier and cheaper to fit another diff and axles than take mine off to repair it. Of course if it can be fixed without taking the whole thing off that would be brilliant.
sounds like the bush that supports the diff flange, if they mean you can wiggle the inner CV where it goes into the diff then there is always play on this, its normal, I've found that it only needs replacing if its actually leaking oil. Otherwise its ok.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by TonyN View Postsounds like the bush that supports the diff flange, if they mean you can wiggle the inner CV where it goes into the diff then there is always play on this, its normal, I've found that it only needs replacing if its actually leaking oil. Otherwise its ok.
mines leaking and very very wobbly
dont know the technical term for this part and have spent most of the morning trying to work out which it is
if someone can tell me what i need to order from here for my LN130 it would be very very usefull
would i be right in thinking its this
if it is, am i right in assuming its drive shaft right out, fit seal, put drive shaft back again, or can it just be pulled out a little and fitted?
any help would be great as I've been usingt he search button all mornign and this is the closest I've come to it.
thanks
