32" rubber, what does it take?
Oops. I meant in terms of front arch or inner wing etc. Because of the small offset of the wheels I have, they "just" touched the chassis rail area on full lock.Originally posted by TonyN View Posthuh?
And the tyres do look a lot better set to the outside of the arches....!
www.johnthebuilder.info
Again, thanks for the reply's guys, I'll start out with the roughtrax 2" lift and go from there, anything else I have to consider when doing a 2" body lift?
I know I'll have to:
-Extend the shift levers (transfer case and manual trans lever)
-Relocate front bumper
-Remove lower fan shroud
Will I need extended brake lines with a 2" suspension and 2" body lift?
Not really, although a 1" block under the rear brake line splitter on the back axle is a good idea if you're going to offroad it.Originally posted by clys View PostWill I need extended brake lines with a 2" suspension and 2" body lift?
Its not a bad idea to get braided hoses front and back, they are normally longer than stock to allow for lifts.
Try cutting the shifter opening a little if you don't fancy extending the levers.4x4toys.co.uk - Keeping you on and off the road...
