91 Turbo Diesel - Power Steering Vibration
  • 91 Turbo Diesel - Power Steering Vibration
    Can anyone help ? my LN130 import drives and steers ok when on the move, but when stationary you get severe vibration when you try and turn the steering wheel, ie when manoeuvring whilst parking etc.
    Hows the power steering oil level? it may be low on oil.
      The belt is loose.
        The belt is loose.
        ..... or a combination of this and a loose bolt. The pivot bolt that mounts the pump to the bracket, is known to come loose (happened to me recently) and tightening the belt just puts more strain on this and can damage the bolt, because the pump moves around.
          Fluid seems ok, as does belt tension - i think pump is going :-(
          Anyone know how to get replacement ?
            http://www.hiluxsurf.co.uk/forums/fo...c&daysprune=-1
            http://www.hiluxsurf.co.uk/forums/forumdisplay.php?f=21
              i should have a power steering pump at the unit.I will check on Weds if i'm not there before and let you know.If i have then £70 delivered
                any luck on pump ?
                  Sorry Stephen i will let you know for definate tomorrow
                    Sorry Stephen i thought i replied to this last week.I have one on the block i got here
                      The belt needs to be tighter than you think (and tighter than the manual says). Also if the belt is worn, it may not be sitting correctly in the pulley.
                        Message to Stormforce, how do you want to arrange payment & shipping ?
                          paypal is good with me Steven. stormforce1067@sky.com It will be monday before its sent out as i am up and down the country for the next couple of days.
                            The pump will be with you for tomorrow Steve.Its with APC (carn logistics)
                              Pump received, many thanks.
