Can anyone help ? my LN130 import drives and steers ok when on the move, but when stationary you get severe vibration when you try and turn the steering wheel, ie when manoeuvring whilst parking etc.
91 Turbo Diesel - Power Steering Vibration
..... or a combination of this and a loose bolt. The pivot bolt that mounts the pump to the bracket, is known to come loose (happened to me recently) and tightening the belt just puts more strain on this and can damage the bolt, because the pump moves around.Originally posted by Albannach View PostThe belt is loose.
Nev
The belt needs to be tighter than you think (and tighter than the manual says). Also if the belt is worn, it may not be sitting correctly in the pulley.Originally posted by stephens64 View PostFluid seems ok, as does belt tension - i think pump is going :-(
Anyone know how to get replacement ?Do you know that, with a 50 character limit, it's
paypal is good with me Steven. stormforce1067@sky.com It will be monday before its sent out as i am up and down the country for the next couple of days.https://www.facebook.com/groups/henpals/
