hi all bit of a problem with the old autobox. seems to be slipping gear after about 30mins continuous travelling may go form O/D to a lower gear for a bit then correct its self and go back to the gear it was in to begin with. if turn O/D off then problem seems to go away but has done it once in the last day or so.
bit of background the kickdown swtich is not wired in. its the lexus gearbox, the ECT isnt wired in, the magnetic speed sensor is working but the one on the TC is the surf speed sensor not the lexus sensor and giving a reading a 5th of the true speed on the combimeter.
any thoughts anyone?
