hi all ... its time to change the n/s lower ball joint . is it easy to fit ? and is there a pateculour way to change it i have a k reg 2.4 surf many thanks
it just looks a bit tight in there will it come out ok ... i was speaking to a friend and he said i had to strip the hub down to do it ? hope not will give it a go lol
It will come out no bother. The joint its self is bolted to the hub and the pin goes down through the wishbone. It's one of the easiest Ball Joints I've ever done!
