Right, my new caliper is fitted and combined with fitting both rear halfshafts I lost a lot of brake fluid.
I bled the brakes in this order, no leaks in the system were detected.
I adjusted handbrake prior to bleeding and it works fine.
New pads fitted in fronts.
Rear LSV bleed nipple, took a long time to get all the air out, then n/s rear brake cylinder followed by o/s brake cylinder.
Then n/s front caliper (the new one) and then the o/s caliper.
The brakes pedal with engine off was rock hard and not sinking.
Turn engine on and brake pedal got easier to push due to servo assistance but continued to sink towards floor.
Bled whole system again, same result but this time pedal never reached the floor with engine running but still a lot of pedal travel, pumping the pedal gave less travel but the brake light on dash illuminated and the brake feel went very hard but less effective braking, another lighter press of pedal and the light went off but pedal sank.
I have brakes but just not good ones and the pedal will sink if you keep pressure on it.
No leaks and fluid level is not dropping.
Has the master cylinder had it?
If so, can Rich or any of the breakers help me out?
