OK... so the new surf wasn't quite as good 'off the boat' as I had originally thought.
Turns out the main exhaust box is blowing and the tail pipe has all but broken off at the flange.
So, I've ordered the two back sections from Milners, along 2 x sealing rings.
Now to the questions... I haven't even considered fitting an exhaust myself for at least 20 yrs, but I do remember it wasn't a lot of fun! Does any one have any suggestions for getting the two flange bolts undone, I have tried squirting liberally with WD40 (several times), but I can't get them to budge. I'm coming round to the idea of getting the angle ginder out and cutting the heads off the bolts.
Secondly, assuming I get the old pieces off... do the sealing rings go in dry or is there any kind of sealing compound that should be used.
Thanks,
Alan
Thanks,
Alan
