Hi All,
Since replacing the bushes on the wishbones my camber seems out a bit.
The Surf looks 'knock kneed' from the front!
I know how to adjust it using the adjustable bolts through the wishbones BUT my questions are:
Is there anywhere on the top wishbone to adjust camber as well?
The reason I am asking is that if I pull the wheel in much further the shock is going to scrape against the bump stop!
There doesn't seem to be enough 'play' for me to pull the wheels in to correct the camber!
I have had this before!
Also, I presume that both sides should be set identical?
My local places don't have a clue and can't be arsed attempting this!
Thanks,
Gary
Thanks,
Gary
