eml on
  • eml on
    hey people. my light is on. so i did the paperclip chek and have narrowed it down. 2 coolant temp sensor. turbo sensor or air mass sensor. as it still has full power and boost. i would imagine it only to be coolant temp sensor. when i start it up 1st thng. it runs lumpy for 40 secs. i hav to hold the revs. and then when driving. wont engage top gear. (AUTO BOX 3.0). any ideas????????
    Yep, coolant sensor. It won't 'lock-up' until the ECU thinks the engine is warm.
    eml?
      eml=== Engine Management Light. === cheers dude. now do i ebay or roughtrax the badboy.. cheers
        Breaker. IIRC this is a very expensive sender.
          Check the plug on the sensor first, could be a break in the wiring due to heat and vibration.
            do u know wher it is vince? it may just b full o crap. i was up to the handles in the river.
              I know where it is, you really should have asked me too...
                hehe . wher is it dude? u i did tell u wot eml is... so u owe me. lol
                  sorry to interrupt...
                  whats the paperclip check?
                  私のホバークラフト は鰻が一杯です。
                    That doesn't count, you made it up yourself.
                      Reading the ECU fault codes. Use a paper clip to bridge the contacts in the test socket.
                        eml is the term we use at the dealership. all that aside. can ANYBODY tell me wher the coolant temp sensor is??
                          Not sure on the 3.0, but on the 2.4 it's under the inlet manifold.
                            Same on the 3 Ltr. Not sure of exact location but somewhere near centre of block. Same sensor as the 2.4.
                            Nev
