Hi All,
I came to the conclusion that all my braking and shock scraping issues were caused by worn wishbone bushes.
Anyhow, I stripped it all down today and to my horror there are some aftermarket bushes in situ, does anyone know how the hell to get these out?
There are stuck solid!
Also, are these the bronze bushes that should be replaced when you have the hub off?
Upright Bronze Bush Outer?
Upright Bronze Bush Inner?
Also, when the bushes have been replaced and the bolts being put back on is there anything I should do, I noticed an adjusting type set up on the bolts?
Are there marks on the wishbones that these have to line up to?
Thanks!
Thanks!
