It's a shame your all the way down in Cornwall mate
Is my Truck safe....
You don't have to get a bodylift if you fit a suspension lift.
I'm wondering if the garage are taking the p*ss.
Perhaps they noticed a bit of wear in them last year, told you and billed you for the work but didn't actually do them. Now this year the same wear has been noticed and the mechanic has flagged it up.
Just my suspicious mind, but my truck never goes into the garage unless it is an absolute necessity, I just don't trust them.Alan
as the ball joints failed before the end of the warrenty year, as identified by the garage, they should replace them, i would be in his face demanding they do the work for free, i replaced both my lower ball joints with milners ones, one failed within the year, called milners and they replaced it with no question. Think you need o read the bloke his fortune cos he is taking the p.issSWIFT AND BOLD
Originally posted by KERRSURF View Post.... my truck never goes into the garage unless it is an absolute necessity, I just don't trust them.
Rear Diff swap
new front quarter
suspension lift
body lift
etc
etc
what would you call absolute necessity then , if the above wasn't ?私のホバークラフト は鰻が一杯です。
This is the same garage that gave you the stupidly expensive bill for CV boots?
I'd give em a wide berth after you get the work done under the warranty that comes with the balljoints you got fitted, the work they did however will only be guaranteed for 3 months in most cases, so you will probably still have to pay for labour.Alan
Originally posted by blackpoolsparks View PostNew head
Rear Diff swap
new front quarter
suspension lift
body lift
etc
etc
what would you call absolute necessity then , if the above wasn't ?Alan
Originally posted by Striker73 View PostIt's a shame your all the way down in Cornwall mate
As said you don't have to have a bodylift to have a 2" suspension lift.You can have one or the other and both if you wanted.I'm more than happy to fit the kits if you wanted to come down for a weekend or something and spend a day fitting everything and i don't charge very much either.https://www.facebook.com/groups/henpals/
Sparks, did my tip for the tensioner work ok mate?
Your getting pretty handy on the tools yourself mate!
Feels so much better doing a good job yourself and perhaps learning something along the way than paying the garage to bodge it.Alan
Brians tip of turning the engine round twice by hand saved me new valves, rods and who knows what else.
What a difference being a few teeth out makes.
had to devise a vice with my spring compressors as havent got round to buying one yet.
Worked a treat
Thanx
collecting your compressor at 5 tomorrow私のホバークラフト は鰻が一杯です。
Originally posted by blackpoolsparks View PostBrians tip of turning the engine round twice by hand saved me new valves, rods and who knows what else.
Worked a treat
Thanx
The turning the engine tip is actually Albannachs tip.Alan
Originally posted by stormforce View PostWhere is Long Eaton then? I've heard of it but can't think where it is at the moment
