Howdy
I'm from the states and recently bought a half cut 1KZTE to put into a 4runner...I did all of the work and drive it around for two days. Unfortunately on day 2 it started running on 3 cyl. I did a lot of tests, found 110 PSI in #1 and 500 in the other three jugs.
Pulled the head, looks good. Pressure tested and valves held vacuum.
Bore hole of #1 looks scraped a wee bit. Pulled #1 piston and found it was cracked. Bearings look good at least.
So now I'm looking for a rebuild kit. I can see in the other 3 bores were the rings had stuck as if the car had sat for a long, long time.
Does anyone know of a good kit?
Mods, please move this wherever it needs to go. Thanks
