The title says it all.
Over the past month I've noticed the surf has been taking longer to start if it's been sat for a few days. Then it sounds v rough for 30 seconds or so.
Tried to go out this evening and the engine turns over but no start
I've tried the primer on top of the fuel filter and it does get hard. When this problem started I changed the fuel filter straight away so it's not that
Please help,
I'm running on bio diesel, and the tank is down low so I may try and put a few liters of normal in; what do you guys think?
Please help,
