Hi all,
I've followed the forums for a while now since buying my truck last year (K Reg 2.4 2nd Gen) and having sucessfully fixed my turbo after finding advice from searching the forums I thought I would have a go at fixing my steering wobble which has been getting steadily worse.
After taking it to a tyre garage and asking them to change rear and front wheels round and perform a wheel balance and full alignment they got as far as jacking the front wheels up and stopping. They pointed out that there was too much play in the steering and I should get sort out that out first.
Now I'm not a mechanic by any means, but I thought it was time to get my hands mucky and try sorting this myself. I decided to replace the track rods, upper and lower ball joints, steering idler and pitman arm, ordered the parts from Roughtrax and they arrived promtply during the week.
Today I started the replacement process and have got as far as removeing both trackrods (trackrods are still intact - my hands not so much) and I'm now stuck at how to remove the upper/lower ball joints. How is this done? On the upper, I've removed the four nuts on the top but how do I separate this? I've looked at the lower joint and I'm not sure about that either.
Any adivce on how to do this would be appreciated, also how do I move the aircon radiator to get at the nuts holding the steering idler bolts in place?
