hello Mr. niftynev
i've been doing a bit a searching and it seems your the guy who might be able to help me.
My heater doesn't move the air flow when I press the buttons on the dash, so i'll press the feet button and it still has air coming out the windscreen vents (i'm not sure that makes sense hope you know what I mean
) I looked in footwell and found the unit that opens and close the different vents and connected the cable to the pin (which had been taken off) and the cable will 'pull' the pin so it will move down the vents but it won't 'push' it so it won't go back to windscreen without a bit of of manual assistance. Could the cable need tightening (is that possible?) or is the motor just on it's way out do you think?
Thanks very much
Dan
i've been doing a bit a searching and it seems your the guy who might be able to help me.My heater doesn't move the air flow when I press the buttons on the dash, so i'll press the feet button and it still has air coming out the windscreen vents (i'm not sure that makes sense hope you know what I mean
) I looked in footwell and found the unit that opens and close the different vents and connected the cable to the pin (which had been taken off) and the cable will 'pull' the pin so it will move down the vents but it won't 'push' it so it won't go back to windscreen without a bit of of manual assistance. Could the cable need tightening (is that possible?) or is the motor just on it's way out do you think?Thanks very much
Dan
