[QUOTE=TonyN]Bad rust in the coolant system is a sign of exhaust gases in coolant, as well as just old weak coolant. I assume your coolant is new, seeing as rad was changed, so the head/gasket would be high up on the list of suspects
Hi Tony well as i have been driving for ages on mine (untested) it seems that it is finally showing me what i did not want to know.
I have had a water leak for some time now and although i was initially refilling with coolant i am now filling with Water.. just recently its started to rust the water up and generally still drinks water. so I refill the over flow tank and keep on top of it that way. Driving it daily and every so often put a few hundread miles on it and as long as i keep it topped up it seems ok.
Reason for posting !!!
Is there a rough guide as to how long this will last?
I know the quotes will be how long is a Piece of String but idealy is it worth just keep driving till it finally gives up.
