I'm trying to fit freewheeling hubs, the AVM ones in this sticky http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=60178
My problem is that when I re-fit the centre bolt, the whole hub locks up, I can't turn the wheel. It looks to me like the centre bolt shouldn't be re-fitted. Fitting it seems to lock the drive shaft to the hub as the washer diameter is greater than the inner diameter of the splines on the manual hub and the drive shaft now sits back in the hub, rather than proud of it, if you see what I mean? I can't find any reference to not re-fitting it. I only see references to fitting it back on.
Anyone got any ideas?
