no the wheel bearings are still in use
Freewheel hubs Problem
Just to help a novice out would you care to explain how?Originally posted by stormforce View Postno the wheel bearings are still in use
From what I can make out, once the hubs are in free wheel mode, they only spin on the bearings in the free wheeling hubs. Like I said, I'm a novice, so how are the original bearings being used?
I'm just thinking back from when i fiited them to my old surf and that was a few years ago now.I will post back once i have figured it out but i'm sure the bearings were still there.Its been a good 7-8 years now since i last fitted themOriginally posted by Bonk View PostJust to help a novice out would you care to explain how?
From what I can make out, once the hubs are in free wheel mode, they only spin on the bearings in the free wheeling hubs. Like I said, I'm a novice, so how are the original bearings being used?https://www.facebook.com/groups/henpals/
Just found this thread which might help
http://www.hiluxsurf.co.uk/showthread.php?t=60178
Your swapping out a part the fixes to the hub which locks the drive shaft.Once the fwh hub is fitted it has a brake type system which when unlocked allows the complete hub to turn and when locked will lock the hub to the shaft.The wheel bearings still need to be fitted in the hubs else the hub will fall offhttps://www.facebook.com/groups/henpals/
Thanks. I think I get it now.Originally posted by stormforce View PostJust found this thread which might help
