I'm planning to replace the coolant in my 3l surf.
I've asked in another thread and got some info, but not enough for me to feel I can proceed...
Albannach gave this advice :
... which is all great advice, but what I don't know, is HOW to do all this...!
How do you back flush?
How do you flush the heater matrix seperately from the radiator?
I had been under the impression it was a simple case of letting the water out of the rad through a tap of some description at the bottom of it??
Back flush suggests reverse pressure somehow...?
If I put a hose into the top of the radiator and gently flush it with fresh water for a while, will that flush the sustem? just the rad I presume..?
Which of the Halfords coolant's is suitable? They do a 5L one for £18 - that could be diluted up to 10L which should be enough for it all??
Any particular reason the thermostat should not be pattern part?? It's not the most complex part ever...?
Oh, and this will seem a dead stupid question, but, er, how do you actually GET the thermostat out??
Originally posted by Albannach
View Post
