hi all happy new year to you i have a 1990 2.4td my problem is when i operate the 4wd button i have no light on dash and no 4wd the relays are working under dash assembly.i was told that if i swap the vacum pipes under the bonnet on the drivers side inner wing this would work ? i tried this but i cant here or feel any suction or blowing on any pipe?please can anyone advise pls pls pls thanks in advance.WHAT AM I DOING WRONG 41 views no reply am i set up on site ok thanks yours hoping colin....
4wd no light no 4wd?
This has been discussed to death, have a look at the links at the bottom of this page, that'll help. Normally it's a loose or broken vacuum pipe.
Scrub that, they've been skewed by the light reference.
Search for ADD or four wheel drive. Have a look through the tech threads too.Do you know that, with a 50 character limit, it's
Fetch it up to me this week-end Colin, I'll sort it out.Originally posted by c elliott View Posthi all happy new year to you i have a 1990 2.4td my problem is when i operate the 4wd button i have no light on dash and no 4wd the relays are working under dash assembly.i was told that if i swap the vacum pipes under the bonnet on the drivers side inner wing this would work ? i tried this but i cant here or feel any suction or blowing on any pipe?please can anyone advise pls pls pls thanks in advance.WHAT AM I DOING WRONG 41 views no reply am i set up on site ok thanks yours hoping colin....
Welcome on board by the way, enjoy your stay.
