Hi all,
My heating isn't working :-(
I guess it's either a blockage going to the Matrixes or air in the system - How do you bleed it?
The front heating get slightly warm, the rear stays cold - here is my strange idea: if I fitted a small electric water pump on a switch (possibly a windscreen washer pump?) inline/ parallel between the matrixes this should push the water around making it more efficient (once the engine is hot)
Any one else think this is a good idea? I just want to be warm 'cos it's ###### cold out!
