Hi all, nice to join the group.
I have a 93 SSRX 2.4 TD Surf, the problem I have is since the cold weather has hit my beast refuses point blank to start. It was always slow to start before but when burst into life always ran sweet as a dream throughout the day, even after leaving it for several hours. The 80 amp fuse is not blown, both batteries are sweet and the glow plugs have been replaced with the NGK type from Roughtrax and the same match to the ones that came out. I cant see any leaks from the primer pump to the fuel injector pump, or the injectors but thought with the age of the beast I may have a slight back flow in the fuel, "the one thing I did notice over the last few weeks is this starting problem got increasenly worse since adding Redex Diesel treatment", and maybe caused a small leak in a seal somewhere, I cant seem to find any bleed screws on the primer or the pump itself to try and cure the back flow " if indeed that is the problem".
If anyone can help or give any advice, hints or tips it would be appreciated as I am missing my pride and joy being on the road.
