Bit of a long shot, but I'm hoping someone may be able to help. I'm in the process of getting my 3rd Gen registered in Finland but need a very specific weight figure. As well as the usual weight or mass figures, they need the axle weight: so the weight at each wheel. Can't find these figures anywhere in the tech specs and Toyota were no help here at all.
Axle Weight
For future reference.
I managed to get this info from a Toyota dealer in Osaka and via an importer friend.
VZN185W
Classification no. 019
Front: 960kg
Rear: 810kg
Total: 1770kg
Classification no. 020
Front: 970kg
Rear: 820kg
Total: 1790kg
No-one knew what the difference in classification is. Not even the dealer. I'm guessing it's just spec options.1996 VZN185 3.4 V6 SSR-G
VZN185W
Front: 960kg
Rear: 810kg
Total: 1770kg
Front: 970kg
Rear: 820kg
Total: 1790kg
Think it may be manual and Auto, I have this info in my book, will have a read and confirm.Nissan Patrol for on-road, and a Land-Rover 110 shed for off-road :-)
this is from the aussie website
http://www.toyotasurf.asn.au/techsite/index.htm
the glovebox manual can be downloaded at this site might give you some more info?
http://www.toyotasurf.asn.au/techsite/downloads.htm
HILUX SURF 2.4 Litre General Vehicle Specifications
Fuel Capacity 65 Litres
Towing Capacity 1500 kg (with trailer brakes)
LN130 1985 - 1993 2.4Litre Turbo Diesel
97HP @ 3800rpm
240NM @ 2400rpm
LUBRICATION SPECIFICATIONS
ENGINE - sump capcity 7 Litres (With oil filter)
COOLING SYSTEM Oil Type :
- Capacity - 9 Litres
MANUAL TRANS Oil Type :
- Capacity - 3.9 litres
AUTO TRANS Oil Type :
- Capacity - 6.5 Litres (Dry Fill)
- Capacity - 1.2 Litres (Drain and Refill)
TRANSFER CASE Oil Type :
- Capacity - 1.1 Litres
FRONT DIFF Oil Type :
- 1.9 Litres
REAR DIFF Oil Type :
- Capacity - 2.2 litres
BRAKE & CLUTCH - DOT 3 type
ENGINE FIRING 1 - 3 - 4 - 2
IDLE SPEED - Manual - 700rpm
- Auto - 800rpm
- Aircon Idle Up - 950rpmLast edited by dannyboy77; 3 February 2010, 13:38.http://www.hiluxsurf.co.uk/showthread.php?t=55797
The only problem with that list is that it relates to a 2.4, and I was after 3rd Gen KZN185 or VZN185. I went to that Aussie site but all their KZN185 links appear to go nowhere...
Anyway, the Surf is now registered so problem solved. In true Finnish style, after spending weeks getting those figures, they wanted an additional figure they failed to previously mention AND the axle weights they wanted were MAX axle weights, not unladen!! I told the guy inspecting the car that after weeks of solid searching, I could say without any doubt that those figures didn't exist. Luckily he was quite helpful and went away with my reams of spec lists and came back with some 'magic' figures :P
Finland has got to be one of the most difficult countries to move to in bureauracratic terms. EU? What EU? Unless you are coming from another Nordic country, you may as well be coming from Russia. And if you know anything about Finnish history, that's not very good... Hard work, but such a rewarding country in the end.Last edited by Nicely; 4 February 2010, 09:40.1996 VZN185 3.4 V6 SSR-G
VZN185 or KZN185. If you find it, can you please post a link to the source, or scan it if it's in a book. They need to know the source of the info.
