Rear window motor
  • Rear window motor
    Not sure if this is common knowledge? I had to replace my rear window motor on my 2.4 ssrx last week, and guessed it may be used in other Toyotas from around the same time. A bit of digging on ebay, and a trip to a local breaker, found the Mk2 MR2 drivers side is identical. And much cheaper.....
    Hi, from memory think the Toyota carina, supra, corolla front passenger window motor is the same as well
    My 4x4
    My choice
    Back off
      Also the Toyota Hiace motors are the same
        may be wrong but was told rear passenger door on the surf is the same as tailgate one as well.Havent checked this but worth mentioning.
        Me........... NEVER
          the surf drivers side will also fit by turning it 180degrees to fit the tailgate
