Not sure if this is common knowledge? I had to replace my rear window motor on my 2.4 ssrx last week, and guessed it may be used in other Toyotas from around the same time. A bit of digging on ebay, and a trip to a local breaker, found the Mk2 MR2 drivers side is identical. And much cheaper.....
Rear window motor
Hi, from memory think the Toyota carina, supra, corolla front passenger window motor is the same as wellOriginally posted by colh View PostNot sure if this is common knowledge? I had to replace my rear window motor on my 2.4 ssrx last week, and guessed it may be used in other Toyotas from around the same time. A bit of digging on ebay, and a trip to a local breaker, found the Mk2 MR2 drivers side is identical. And much cheaper.....Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
the surf drivers side will also fit by turning it 180degrees to fit the tailgateOriginally posted by tillytops View Postmay be wrong but was told rear passenger door on the surf is the same as tailgate one as well.Havent checked this but worth mentioning.https://www.facebook.com/groups/henpals/
