Hi guys,
Had the dreaded overheat problem on Friday taking my caravan off for the weekend. Not sure why it happened but I was running with the ECS on and noticed the temp guage was well over to the right just before we got to a
rather steep hill leading up the A417 just outside Cheltenham. We'd only done about 5-6 miles, all mostly on the flat by then. Managed to get to the top by putting the heater on with the fan at full blast, which cooled everything back down OK. When I had a chance to pull in a layby to check the rad I noticed the fan turned very easily, so obviously I've got the problem of lack of oil in the fan clutch.
So here's my question. On a 93 3.0L TD, how do you get the fan off the block to repair it? I'm OK doing anything like this with a manual but the lack of one for the Surf is causing me to take things very easy, especially since I've never worked on a diesel before. Also, has anyone managed to get the correct silicon oil from a Toyota dealer yet? If so, how much and what part number do they use?
The daft part is that coming back today, even driving up a few long hills on the A417 didn't get the temp needle moving off normal at all.
