Anyone know the thread pitch on the 2.4 glow plugs ?
  • Anyone know the thread pitch on the 2.4 glow plugs ?
    Just been quoted £70 for a compression test on the truck. I can buy a tester for that but need to know the thread pitch of the glow plugs. I can measure it at work tomorrow but want to try and get the tester by the weekend if possible. (order asap - ie: tonight )
    Thanks,
    Rob.
    Thanks,
    Rob.
    yeah hang on a minute i have a glow plug hanging from my left armpit i will just messure it for you
    yes 2 inch
      Thanks,
      Rob.
      Try www.toyodiy.com ...... or matts site
        Nev will most likely know the answer to this one.
          yes 2 inch
          I know, I know - you've also got pistons flying out yer eyeballs.... cheeky sod
            Thanks for the input fellas - I'll measure one myself at 7.30 tomorrow morning..
            Rob.
              From memory, it's 10mm.
                Hi Andy, yep it's definately 10mm, but I need to know the thread pitch - We've got the gauges at work to measure but it's 30 miles away.
                Rob.
                  just checked it out for you rob 10mm
                  jap finest
                    You're on fire tonight Tel
                    So is fine thread 1.0, against 1.25 ? That's the 2 options this tester has. Don't want to spend the cash and it not fit. Moneys a bit squeezed right now.
                    Rob.
                      1.25 is my guess, 1mm is a bit fine for something like that?
                        Rob.
                        sorry mate dont know the answer till the morn and threadchek try seaching for glowplug thread chasers they sell them for merc sprinters and peugeots always damaging the threads when you remove them ,there might be one for the yota and they might show there thread pitch.
                          yep im with the sweaty on this one 1 m is very fine
                            Good call ! a search for chasers pulled up this .. (yep I know it's not a chaser but..)
                            Thanks to all,
                            Rob.
                              Bugger, too late. I knew the answer to that.
