Hi folks.
The orange overdrive light on my kzn185 tends to flash after I go over 50kph. According to the manual I should instantly get to my local dealer due to a gearbox fault.
My local Toyota dealer has gone bust, and Toyota Ireland will not even talk to you if you even refer to an import! My mechanic (Landrover & Jaguar) can't find a problem, and I can't find a problem. Overdrive and ECT both work fine, oil levels are fine, and there are no leaks. It runs up and down through the gears without any difficulty.
I can't find anyone locally whose software can reset the light (I want to see is a an old fault that may have been fixed but light not reset, or a false read).
Is there any quick reset, or is there a diagnostic tool/package available?
Thanks.
David.
Thanks.
David.
