Need a little wisdom here, my dad has given me some grease he thinks should be ok on the ball joints (haven't done it yet and not sure when they were last done, if at all), now reading the sticky section it says to use Molydbenum-disulfide lithium based grease NLGI 1 or 2. The grease he has given says it's lithium based and meets NLGI 2 and is ideal for use on pump bearings, universal joints, wheel bearings, vehicle chassis and other routine maintenance but mentions nothing about the Molydbenum-disulfide, it also says it has a high melting point and is multi purpose, since I don't have a clue what all the names and numbers mean, would this be ok to use on the ball joints???
Any help on this would be MUCH appreciated.
