What is the highest ratio you can get for the 8"hilux axle ( i need more top speed )
Anyone know this
would the whole axle need changing or is there any other way round it...Originally posted by ElvzSupras came with 3.133:1 and 3.266:1 8" limited slip diffs and there are probably matching 7½" diffs suitable for the front in some of the RWD Corollas.CHEERS JOHN................
Toyota Supra (and also the V6 Camry) diffs are the same series as the Hilux Turbo/V6 ones but you can't really be sure it will fit unless you know if the car your axle came from was auto or manual. Autos are slightly different and the diff is not interchangeable with manual ones because the carrier inside the axle is different.
If you get the right diff for your axle casing it will just bolt in.
I think one thing you will need to be aware of, just putting a higher ratio diff in will not neccessarily give you more speed, The engine power and resistance on a Surf / Hilux / 4runner will limit the top speed even if you lowere the revs. I certainly can't redline my 2.4 in top. Unless you are putting in a nice powerful V8 or Supra engine you will probably find that putting in the highest ratio diff will actually reduce your top speed.Originally posted by Alg1kWhat is the highest ratio you can get for the 8"hilux axle ( i need more top speed )
Mind you as I don't know what that 8" axle is in, then you may already have the above covered.
Go on, Tell us......please
err think he has it in the dolomite/sprint pictured ??Originally posted by lucky.....Mind you as I don't know what that 8" axle is in, then you may already have the above covered.
CheersMaurice
Doh.Originally posted by Morrerr think he has it in the dolomite/sprint pictured ??
Didn't see that - blindness taking over.
Have a look here
http://www.off-road.com/toyota/tech/other/4_axles.html
From what I can see the highest ratio is 3.333 in the 8" standard. or a 3.15 on an american spec one.
CheersLast edited by lucky; 1 June 2004, 11:41.
Your bravery knows no bounds. 155mph in a Dolomite, they were mad enough at 110.Originally posted by Alg1kCheers for your help everyone
Yes its in the dolomite but its running a ford cosworth turbo engine
With a huge gt series turbo
The thing is it tops out at 155 mph
with the 4.33..1 ratio in it at the moment
Bet that is a site to see.
155mph??? How long are 1/4 miles in the UK?
I run 14.2sec with a trap speed of 102mph on 15psi. If your trapping 155mph you must be running low 9's. HOLY SH!T !!
Was size turbo are you running?91 SSR ltd 2.4td Wine over grey. Currently on head #2.
89 Mazda MX6 2.2 lt turbo.
