Hello people... Im new, to this forum and to owning a hilux, so go easy on me
Bought my 1992 hilux surf 2.4 ssrx about 3 months ago and all has been fine with it.
I decided to test out the high ratio 4 wheel drive via the switch on gear stick. Went into 4WD fine, so i switched back to 2WD. I then realised that the speedo was reading zero, after about 2 minutes jumped back up to correct speed and stayed there rest of journey.
Now nearly every time i go for a drive, for the first 2 minutes of driving the speedo reads zero and then jumps up to the correct speed.
What could the problem be? what did switching to 4WD do?
